Discussion topic: Internet not working
Message posted on 20 May 2025 01:35 PM
Internet down.
Done all the necessary normal things and not coming back on.
Amber light on the box itself for the Internet connection
Message posted on 20 May 2025 01:39 PM
Re: Internet not working
@4nt1hony
Don't know what you class as normal so if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
