Discussion topic: Internet not working
This message was authored by: Rejacksonhunt
Internet not working, website says it is. Turned hub on and off. Still no Internet. Orange light on hub.
This is supposed to be super fast Internet!
Re: Internet not working
@Rejacksonhunt
I have moved your post from the Sky+ board.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
