Discussion topic: Internet not working
Message posted on 29 Apr 2025 12:16 PM
WiFi and broadband internet is down
Message posted on 29 Apr 2025 12:17 PM
Re: Internet not working
@joeangus
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
