Discussion topic: Internet not working
Message posted on 13 Apr 2025 10:11 AM
Internet not working even though I'd done the checks an it says pints all good an it's been this way for around two months I work away so on the one day I'm home I can do nothing with it
Message posted on 13 Apr 2025 10:15 AM
Re: Internet not working
What checks have you done so have you run the broadband line test ?
What lights are lit on your hub and have you rebooted it ?
Message posted on 13 Apr 2025 11:06 AM
Hi yes Iv run the tests an rebooted it an still the same the first light is green but the other 3 just flash amber or not on at all
Message posted on 22 Apr 2025 01:26 PM
Did you try to reset your hub? Sometimes it helps...
