Discussion topic: Internet not working
This message was authored by: NivaRose
My router is on and all the lights are green but none of my devices in my house will connect to my Internet. It is behaving like there is no Internet connection. This is both for WiFi and Ethernet. I have tried to reset the router and my devices and its made no difference
This message was authored by: Fionacath
Re: Internet not working
This is the same for me, what is going on sky?
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
