Discussion topic: Internet not working
This message was authored by: Cristian6
Hi there
The Internet is not working.
Tried to restart the router but still no results.
(removed)
MANY thanks
Cristian
Moderator note: Removed personal/identifiable details
Re: Internet not working
@Cristian6
Your post has been temporarily removed as you've put your home address on a public forum. It should return once moderated.
In addition~
▪️ Any engineer visit that’s required is still likely to be delayed due to the disruption from the recent storms.
▪️ This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
