Discussion topic: Internet not working
Message posted on 10 Jan 2025 05:37 PM
Everything connected and turned on then just lost connection and won't come back on
Message posted on 10 Jan 2025 05:44 PM
Re: Internet not working
@Josh88
Use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
Message posted on 10 Jan 2025 05:45 PM
Done all above, still not working and test on the app says it's fine and it's not
