24 Nov 2023 12:49 AM - last edited: 01 Dec 2023 11:40 AM by Kelsingra
Internet stopped working an hour ago. Can't understand why we are being charged ridiculous prices and yet can't speak to a human after 9pm. Automated phone service told me to follow a link to internet which is not working because I have an 'unstable connection' due to not having WiFi. Anyone else getting (removed) off with Skys constantly failing WiFi
Moderator note: Removed inappropriate language
24 Nov 2023 12:57 AM
Hi @Beverley1, not sure what your area is, but I'm also having the same problem - WiFi stopped working about an hour ago. Tried everything the bot says including resetting the hub but nothing works. I'm in Essex.
24 Nov 2023 01:01 AM
same issue with me, also in Essex CM2.
24 Nov 2023 01:04 AM
Hi @Claire240814, well that's interesting as I'm in CM1! I guess it's a fault in the area then
24 Nov 2023 01:10 AM
Mine went off at the same time and i'm in NI . A short duration outage that may indicate maintenance. If yours isn't back in the morning drop a note here and we can escalate directly to sky
24 Nov 2023 01:13 AM
Thank you, @cookiemonsteruk. Will do!
24 Nov 2023 03:29 AM
My internet is also not working too. I am in LS27.
24 Nov 2023 06:34 AM
Also no Internet. In HP21. 2 mornings in a row I wake up to no Internet.
24 Nov 2023 07:06 AM
Posted by a Superuser, not a Sky employee. Find out moreLine drops between midnight and 5am are likely to be overnight maintenance work of which there seems a lot at the moment.
@Christian0408 if you line is down after 6am and does not recover by rebooting your hub run the connection test in the My Sky app over a mobike connection to see if there is a known fault in your area if there isnt give Sky a call to report the fault or post again and someone can escalate your post for an online chat with Sky.
24 Nov 2023 07:30 AM
Mine not working either in RM16
24 Nov 2023 07:32 AM
Posted by a Superuser, not a Sky employee. Find out more@Essexed have you run the connection test in the My Sky app overca mobile connection as that will tell you if Sky are aware of an issue or not
24 Nov 2023 07:35 AM
Hi Chrisee, yes run it a couple of times. It says there is no outage but can't think what else it can be. Turned everything off multiple times, WiFi still working
24 Nov 2023 07:44 AM
Posted by a Superuser, not a Sky employee. Find out more@Essexed it needs checking out so I am escalating your post to the Sky team who support the forum. Keep your eye out for a message invititing you onto an online chat through the forum where they will add a chat icon.
24 Nov 2023 07:46 AM
Thanks Chrisee
24 Nov 2023 07:51 AM
I've got same problem. Run the test on mobile network. Saying no outage in the area. Had to go work now but this isn't the first time it has happened recently.
