Discussion topic: Internet not working orange light on hub
This message was authored by: Pam1982
Internet checker online is saying all ok no problem but I have an orange light on my hub, and no internet connection
Re: Internet not working orange light on hub
@Pam1982
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
