Discussion topic: Internet not working in other rooms
Message posted on 16 Aug 2025 07:37 PM
Message posted on 16 Aug 2025 07:46 PM
Re: Internet not working in other rooms
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Message posted on 16 Aug 2025 09:24 PM
Received New Sky hub and a Pod. I have 2 boosters which we used for Sky Q but these don't seem to work/ connect to the new Sky Hub 6. We have Sky Fibre 500 which we are getting in the room with the hub but in the room below where the pod is located we are only getting 200mbs. We have a 3 storey town house so the signal on the ground floor in the living room is about 15mbs!!! Will requesting 2 more Pods get me close to the 500mbs I should be getting??
Message posted on 16 Aug 2025 09:30 PM
@Jimbob13 The help information from sky explaining speed and broadband operation!
https://www.sky.com/help/articles/broadband-speeds-explained
