Discussion topic: Internet not working how it should
This message was authored by: Brand
Internet speed aren't up to standard everything is lagging but broadband and WiFi say it's running at over 400 mbs. It isn't
Re: Internet not working how it should
@Brand How do you know?
Avatar for Brand
My sky app says everything is running perfectly speed checkers say it too but I can guarantee it isn't because whatever I do I.e stream something on tv work on the computer it just lags
@Brand So you are saying then that you have a wireless issue is that correct? What hub do you have from sky, Black or White?
