Discussion topic: Internet max
This message was authored by: Ge79
Message posted on 15 Apr 2026 09:51 PM
Internet max
The internet upstairs it's not strong enough.. I should have 900 speed but i only have 200speed...any suggestions? Thanks
Find out more
Message posted on 15 Apr 2026 10:27 PM
Re: Internet max
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link
