Discussion topic: Internet lost connect
Message posted on 14 Aug 2025 10:16 AM
My internet connection is not very reliable; it occasionally loses signal.
Message posted on 14 Aug 2025 12:35 PM
Re: Internet lost connect
@SamSeydi
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
