Discussion topic: Internet light
This message was authored by: Mm03
Internet light
Hi I am having issues with my WiFi. It says everything is fine and the WiFi light is showing as green but no light is coming on for the internet.
Re: Internet light
@Mm03
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
