Discussion topic: Internet light flashing
Message posted on 07 Dec 2025 10:52 AM
The internet broadbrand has not been working for a few hours. The light on the box keeps flashing. All other lights are on. Tried turning the box on and off but no solution, same issue.
Message posted on 07 Dec 2025 11:38 AM
Re: Internet light flashing
@Tajmina
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Red light on ONT; See this link ~ https://helpforum.sky.com/t5/Broadband-Talk/Can-t-connect-to-broadband-and-have-a-red-light-on-your-...
Message posted on 21 Dec 2025 04:04 PM
Internet not working
Same issue as last time. No internet working this evening, no light flashing. Turned the device on and off and still not working.
Message posted on 21 Dec 2025 04:07 PM
Re: Internet not working
Have you now reported it to Sky as suggested after your first post?
