Discussion topic: Internet keeps losing signal
This message was authored by: Sashabost
My internet keeps losing connection Iv not had any issues with it up until yesterday
Re: Internet keeps losing signal
@Sashabost
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
