Discussion topic: Internet keeps going off
Message posted on 09 Apr 2025 06:18 PM
My Internet keeps going off even though it say service is fine. I've turned everything off and on again and got it working for five minutes and now it's gone back off again
Message posted on 09 Apr 2025 06:36 PM
Re: Internet keeps going off
Keeps going off every day for 30 mins then comes back on and every sliw
Message posted on 09 Apr 2025 06:44 PM
@Will103
