Discussion topic: Internet keeps dropping since I have installed sky ring doorbell
This message was authored by: Wolfette103
I have installed sky ring doorbell and now my internet connection is so poor I'm having trouble watching tv as it will say technical fault, my mobile keeps stalling, has anyone else get this problem
This message was authored by: Me134
Re: Internet keeps dropping since I have installed sky ring doorbell
The actual internet signal to the hub or your wifi internal signal?
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not and it is a wifi issue then you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
