Discussion topic: Internet keeps dropping out
Message posted on 30 May 2026 03:56 PM
The internet keeps dropping out the orange light flashes on the hub but then goes off this keeps happening
Message posted on 30 May 2026 03:58 PM
Re: Internet keeps dropping out
@AP522
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
