1
This discussion topic has been answered Discussion topic: Internet keeps dropping out
This message was authored by: MrMorginus
The past few days my internet keeps dropping.  At first I thought it was steam (I had that issue before) but then for a few days my phone kept disconnecting from internet, and when I looked the router light had gone out, so I reset router, and last few days my computer keeps losing internet and router again is losing the light, or if light stays on, no devices can connect to it like it's not on.
This message was authored by: JimM1 Answer
Re: Internet keeps dropping out
@MrMorginus You can run the test at anytime, it may or may not find an issue but follow it as laid out.
Try running the line test here to see if any faults are found:
