Discussion topic: Internet keeps dropping out
Message posted on 26 Oct 2025 02:24 PM
Message posted on 26 Oct 2025 02:28 PM
Re: Internet keeps dropping out
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
