1
This discussion topic has been answered Discussion topic: Internet keeps dropping for hours and days
This message was authored by: Phillies
Router is green for power and WiFi but amber for voice and amber flashing for Internet.
Re: Internet keeps dropping for hours and days
@Phillies
The hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
@Phillies
