Discussion topic: Internet keep dropping
Message posted on 26 May 2026 05:17 PM
My internet keeps dropping for hours at a time. Resetting the router does nothing.
Power - green
Internet - no light
Wi-Fi - green
Voice - orange
Message posted on 26 May 2026 05:31 PM
Re: Internet keep dropping
@dkmb
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 30 May 2026 11:01 AM
Thanks, this was helpful. But I had to call out an engineer to fix the fault with the box.
