Discussion topic: Internet issues
This message was authored by: Lyndsey23
Internet issues
My internet on the hub has a solid orange light, I have tested and there is no known issues
Re: Internet issues
@Lyndsey23 see below!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
or
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
