Discussion topic: Internet issues
This message was authored by: Louise298
Internet issues
The internet is saying connected but no devices are working and I am trying to work from home
Re: Internet issues
@Louise298
There’s a possibility the current heavy rainfall may be causing some broadband issues.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
This message was authored by: LisaStiv90
Re: Internet issues
Mine is the exact same! Really frustrating.
