Discussion topic: Internet issues
Message posted on 12 Sep 2025 09:03 PM
Internet issues
The Internet keeps kicking me off then comming back in it states the WiFi connect is fine online and it's clearly not this needs sorted
Message posted on 12 Sep 2025 09:05 PM
Re: Internet issues
@Deano19
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
