Discussion topic: Internet issues
This message was authored by: Calvy
Internet issues
2 green and 1 orange light only. Normally it's 4 green lights, and TV is stuck while using youtube
Re: Internet issues
@Calvy
This explains the lights on the hubs:
Try running the line test here:
If this is of no help give Sky a call to report it to them.
Avatar for Calvy
Re: Internet issues
The Internet light is not on and I noticed a red light on the white box the LOS light is red.
Obviously an issue yet on sky app using mobile data it says all is good with Internet!!! How is it good when it's clearly an issue! Moved over to fibre not even 3 weeks ago and already issues
Re: Internet issues
@Calvy You can alway's trust what you see physically ,LOS red, fibre is down between home and exchange for whatever reason, would be good that the service checker software found it, but more than likely the diagnostic would do. Have a try and see.
Try running the line test here to see if any faults are found:
This message was authored by: jimeaston1
Re: Internet issues
I have had the exact same issue, I contacted Sky on Broadband Chat and they ran diagnostics and it came back as an issue with the Sky Hub. This is now being replaced so fingers crossed it sorts this too.
Ps also got £15 compensation for inconvenience
