Discussion topic: Internet issue
Message posted on 14 Nov 2025 12:23 PM
Internet issue
Message posted on 14 Nov 2025 12:36 PM
Re: Internet issue
@Robyn44
The current heavy rainfall may be causing broadband issues.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
