Discussion topic: Internet is not working
Message posted on 22 May 2026 10:38 PM
I have problem my Internet I can't watch the TikTok
Message posted on 23 May 2026 03:39 AM
Re: Internet is not working
@Daniel2003
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 23 May 2026 05:40 AM
Is it just Tiktok that you can't access so can you access other websites without any issues ?
