Discussion topic: Internet is not working
Message posted on 22 Apr 2025 09:46 PM
My internet is not working
Message posted on 23 Apr 2025 03:57 AM
Re: Internet is not working
@G+Bhatt
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
