Discussion topic: Internet is 90 should be running at 900 has it been upgraded to 5g.
This message was authored by: Sarah296
We had 5G installed yesterday but it doesn't appear to be running faster as I thought it would.
can you please look into this as my son wanted 5G as he's a gamer rubs a PC Xbox and iPhone but it's the speed he needs.
thank you
Re: Internet is 90 should be running at 900 has it been upgraded to 5g.
@Sarah296
'5G' is a cellular data technology and nothing to do with Sky Broadband.
You probably mean '5Ghz', as in one of the two WiFi bands broadcast from a Sky Hub (the other being 2.4Ghz)
@Sarah296
Note that 90Mbs over WiFi is entirely plausible from a gigabit broadband connection on the other side of a few walls.
Avatar for Sarah296
I appreciate your reply.
At risk of sounding dim! What speed should it be running at?
my son is autistic and is just telling me that it's not as fast as it should be?
thanks
@Sarah296
WiFi cannot deliver the full speed of a gigabit broadband connection: simple physics (ie. distance and building fabric) literally gets in the way.
Ideally ethernet cable is the best solution, as that can deliver the full speed arriving at the Hub.
Powerline network adapters may be viable, although they won't deliver 1000Mbs.
Avatar for Sarah296
Thank you for explaining I appreciate your help.
