Discussion topic: Internet has dropped out again.
This message was authored by: Derekmenmuir
Myy Internet gas dropped out again. We have had 2 engineers out in the oast week and bith assured us the problem was fixed. It has happened again. I work from home and knee again can't work.
Re: Internet has dropped out again.
@Derekmenmuir
