Discussion topic: Internet has crashed again
Message posted on 14 Nov 2025 03:22 PM
Help in rebooting the modem or ordering a new one as it's been awful for too long
Message posted on 14 Nov 2025 03:25 PM
Re: Internet has crashed again
@AdeMilli
There’s a possibility the current heavy rainfall may be causing some broadband issues.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
