1
This discussion topic has been answered Discussion topic: Internet going on and off
This message was authored by: alisonmackay
Hello my Internet has been going on and off the last two days
Re: Internet going on and off
@alisonmackay
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
@alisonmackay
