Discussion topic: Internet going off and on
This message was authored by: Sparky3888
For the past few days now my Hub randomly keeps disconnecting then reconnecting to the internet.Ive moved the Hub location around in my living room to try see if that fixes the issue but it doesn't make a difference.It says there's no faults or connection issues on the app and I'm getting an average download speed of 74.3 mb/s however it just gets annoying when it goes off and on.
Re: Internet going off and on
@Sparky3888
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
