Discussion topic: Internet dropped out
This message was authored by: Staceyc88
Hello my app says broadband all ok however I work from home and my laptop has lost connection also my phone won't connect to wifi says your connection is dropped when I try to connect to it. My sky box also has not got the green light for internet it's orange. So don't understand why the app says Iv got good broadband speed when it's not working or connecting to anything. I'm working from home so would kindly like someone to get back to me Iv done the steps that I got when trying to connect WiFi to my phone didn't work
Re: Internet dropped out
@Staceyc88
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
