Discussion topic: Internet drooped out 40 mins ago
Message posted on 02 Sep 2025 08:00 PM
Message posted on 02 Sep 2025 08:13 PM
Re: Internet drooped out 40 mins ago
@Davidgore Here is the hub lights info for you!
Message posted on 02 Sep 2025 08:18 PM
Message posted on 02 Sep 2025 08:19 PM
Message posted on 02 Sep 2025 08:26 PM
@Davidgore wrote:
That's not helpful
In case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers including @JimM1 are here trying to help other customers.
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 02 Sep 2025 08:29 PM - last edited: 02 Sep 2025 08:30 PM
Information removed as it was the same as posted by Daniel0210.
Message posted on 02 Sep 2025 08:32 PM
Same here! Internet gone down, checked everything to try and fix it but nothing is working
Message posted on 02 Sep 2025 08:34 PM
@Davidgore No problems, the link guides to running diagnostic with the Amber light for Internet failure that can be anywhere from the home all the way to sky server control!
