1
This discussion topic has been answered Discussion topic: Internet down despite Sky test ok
This message was authored by: Oliverd85
Internet is down, orange light on when I run the sky service check it says all is ok?!
Re: Internet down despite Sky test ok
@Oliverd85
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
@Oliverd85
