Discussion topic: Internet doesn't work
This message was authored by: Svitlana3
Hi
Today internet is poorly
Red light on router
Re: Internet doesn't work
@Svitlana3
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
