Discussion topic: Internet cut out
Message posted on 11 Jan 2026 05:42 PM
Internet cut out
Message posted on 11 Jan 2026 06:00 PM
Re: Internet cut out
@Marlon1991
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
