Discussion topic: Internet constantly not working
This message was authored by: Kayls
Internet constantly not working. Been like it for over a year, sometimes acts fine, then will get a continuous period of the internet going down. App saying everything looks fine. When contacted Sky a year ago, was told only way to solve was to upgrade, but kept getting messed about so decided to leave as is. Just want a solution for the internet to not go down all the time. Been going off every 10 minutes or so as of an hour ago.
Re: Internet constantly not working
@Kayls
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
