Discussion topic: Internet constantly dropping out
Message posted on 15 Dec 2025 01:06 PM
Over the last week I've been having reoccurring issues with my internet dropping out.
I work from home and therefore require a reliable internet connection.
Message posted on 15 Dec 2025 01:18 PM
Re: Internet constantly dropping out
@Jasmine46
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
