Discussion topic: Internet constantly dropping out
Message posted on 14 Dec 2025 06:08 PM
Probably not, but am I the only one experiencing this?
Internet drops out daily - 5 times so far today & I can't remember the last day when it didn't.
MySky app simply says there's a problem, eventually does its test, then says everything is fine - only to go off minutes late.
Took me 3 attempts to post this without it happening again!
Message posted on 14 Dec 2025 06:25 PM
Re: Internet constantly dropping out
The normal advice is firstly try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
is
