Discussion topic: Internet connection
Message posted on 08 Sep 2026 02:07 PM
Internet connection
Why are some devices losing connection to the internet when not in the same room as the hub?
I've given it a couple of weeks after being installed yet it is still happening
Message posted on 08 Sep 2026 06:07 PM
Re: Internet connection
A poor signal is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
