Discussion topic: Internet connection
This message was authored by: PiperM
Internet connection
Keeps drifting in and out, been like this for days now. You say there are no issues but we leep
losing signal which is being very annoying
please sort
Re: Internet connection
@PiperM
You aren’t actually contacting Sky by posting here as this is a customer ▶️ customer discussion forum where we try to assist other customers.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
