Discussion topic: Internet connection
This message was authored by: Joanne147
Internet connection
Having continued internet disruption. Check on the app and it says there is no issue with connection. Can't use phones on WiFi watch tv
Re: Internet connection
@Joanne147
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
