Discussion topic: Internet connection
This message was authored by: Gullu1
Internet connection
My internet is really bad it keeps cutting off I need it checked
Re: Internet connection
@Gullu1
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This message was authored by: Chelsea92
My tv not working it's saying no signal
@Chelsea92
You have added to a thread about broadband connection. Which Sky TV platform do you subscribe to?
