Discussion topic: Internet connection
This message was authored by: Alex297
Internet connection
My router is showing an amber light under internet, connected devices connect then drop off
Re: Internet connection
@Alex297 See if the linked information is helpful to you, by now you may be fully back up and running!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
