Discussion topic: Internet connection
Message posted on 17 Nov 2025 04:00 PM
Internet connection
No internet connection it's not doing anything
Message posted on 17 Nov 2025 04:04 PM
Re: Internet connection
@Shas66
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
Message posted on 17 Nov 2025 04:33 PM
It says it's still out
