Discussion topic: Internet connection
This message was authored by: Teddypickle
Internet connection
There is a problem with my router believe it's at your end but need an engineer out as soon as possible please as I can't watch only normal television
Avatar for Teddypickle
Re: Internet connection
Please send an engineer out ASAP
@Teddypickle
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
What makes you believe it's a problem with the hub?
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
